Can't open a nifpga session of labview bitfile
I ran into an issue that I can no longer start a session for labview bitfile. The python host interfaces with labview bitfile with write and read FIFOs. Python codes and errors are below. Same exact codes worked reliably until last week.
with Session("ccsdsbytecontrol_PXIe-7971R_CCSDSByteControl_nS419VaXs08.lvbitx", "PXI2Slot6") as session:
# Initialize FIFOs
write_fifo = session.fifos['Write_FIFO']
read_fifo = session.fifos['Read_FIFO']
write_fifo.start()
read_fifo.start()
Error happened with Session command:
Traceback (most recent call last):
File "C:/Tuan/Test/lvds_py38/main.py", line 100, in <module>
runByteController_python()
File "C:/Tuan/Test/lvds_py38/main.py", line 61, in runByteController_python
File "C:\Tuan\Test\lvds_py38\venv\lib\site-packages\nifpga\session.py", line 118, in __init__
self._nifpga.Open(bitfile_path,
File "C:\Tuan\Test\lvds_py38\venv\lib\site-packages\nifpga\status.py", line 99, in internal
status = function(*args)
OSError: exception: access violation reading 0x00000000000000D0
Process finished with exit code 1
Message 1 of 1
(488 Views)
