Can't get Basic Serial Write and Read.vi to run
This is a strange problem because I've used this particular .vi many times before and never had a problem until I set up LabVIEW on my new laptop. I installed everything as I should without issue but for some reason when I try to run, I get the message:
"Error -1073807343 occured at Property Node (arg 1) in VISA Configure Serial Port (Instr).vi-> Basic Serial Write and Read.vi
Possible reason(s):
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system. "
I have tried looking for the error in the forums but it never matches what I am doing and I cannot find a solution. This is a serious problem because I am on a timeline to hand in a project. Please advise.
Yusif
(2,665 Views)
Accepted by topic author Akello
Dumb question - is the right port selected for your new laptop? Maybe it is something like com5 instead of com1. Do you see the port in the Windows device manager?
LabVIEW 2012
(2,660 Views)
Brilliant...I'm an idiot. I tried this at home and something was faulty so I was trying it at work without anything connected to the port. Thank you for showing me my error.
(2,654 Views)
