Can't find regular expression inside of some VI's, even though they have it.
Using "control F", I can't find regular expression (string as case name) inside of some VI's, even though these VIs have it.
I tried to check the properties of these VIs, but didn't find anything different from the VIs, where this expression was successfully found.
What is the problem ?
Message 1 of 8
(1,486 Views)
Message 2 of 8
(1,463 Views)
It should work as you are expecting, Make sure you have selected Text in the Search For option.
Try to share the Source File/Sub VI and the regular Expression you are searching for.
If you have Front panel Control Indicator with lot of data you can select Search Text Options
Message 3 of 8
(1,465 Views)
Duplicate Post
Message 4 of 8
(1,452 Views)
Thanks for your reply. I tried the "Text Search Options". It doesn't help.
I can share with you a source (626 MB) using "jumbomail" -  https://www.jumbomail.me/he/
If it acceptable for you, - I need your E mail.
Message 5 of 8
(1,452 Views)
If possible share the Sub Vi's/Modules where you are predicting the issue.
Preferably in LV2020 or Lower version.
Message 6 of 8
(1,447 Views)
Or make a snippet out of the controls/indicators where you are experiencing the problems.
Message 7 of 8
(1,405 Views)
It is LabVIEW 2018
Message 8 of 8
(1,371 Views)
