Can't find Secondary DLL error....
Hi guys,
I'm attempting to run a LabVIEW vi that uses a Call Library Function on a different computer than it was created on and I'm getting a "can't find secondary DLL" error when loading the vi. Now the vi works on the computer I developed it on, but it can't find the DLL on the new computer I'm trying to use it on. I read an earlier post regarding this and the suggested solution was to modify the paths that the computer uses. I modified the autoexec.bat to point to c:\windows where I placed the DLL. However, I still get the same error.
So 2 things: is there another place where windows paths are set? More importantly, how can I fix this "can't find secondary DLL" problem? Thanks.
-Mike
(3,249 Views)
hello mike
This problem appears when your own DLL calls an other DLL. for example acqimage.dll call epix.dll which manages the imaging acquisition board. This last DLL must place in \system32 or \system
best regard
jerome
(3,249 Views)
Ooooooh,
I see. I've been toying with my DLL and the code I used to generate it and I can't seem to determine what the secondary DLL could possibly be. I used C to develop the DLL. This is my header:
#include "extcode.h"
_declspec (dllexport) long avg_num(float a[], long size, float *avg);
Is there a standard LabVIEW or Visual C DLL that's being called to this? Thanks, I appreciate it.
-Mike
(3,249 Views)
I looked ours up (we were running into the same problem) and found that the Visual C++ documentation lists the DLL's that are used for various functions. For VC++ 5.0 the required DLL's (put them in the system32 directory) are:
Msvbvm50.dll
Msvcirtd.dll
Msvcp50.dll
Msvcp50d.dll
MSvcrtd.dll
sicl32.dll
Notice that most of them start with Msvc. Take a look at your developement system and see what Msvc*.dll files are there. Copy what you need.
Rob
(3,250 Views)
This sounds like the problem I am having, can someone run through the exact steps that I need to follow. I need to add secondary .dll in an NI device, particulary a PXI-xxxx.
Message Edited by Newguy100 on 08-30-2005 02:53 PM
(3,156 Views)
