Can't find SIM file after installing 8.2.1
I just installed LV 8.2.1 including the real-time module on a Win-XP pro system.  When connecting to the RT target (cFP-2110) it searches for and cannot find several "SIM" files.  For example, it cannot find SIM Diagram Parameters.ctl and many others.  It attempts to find them in the vilib>:\Simulation\Utility\Implementation\Shared\ folder.  The closest file path that I have is LabVIEW 8.2\vi.lib\simulation\Implementation\Shared folder.  There are several "SIM" files in this folder but not what the system is looking for.
The system eventually connects to the target and it seems to work.  However, it's a cumbersome effort to connect.
Please advise.
Dave J.
(2,946 Views)
If you had an upgrade from LV 8.2 to LV 8.2.1, you could have the problem described by this page, and the fix is pretty easy:
http://digital.ni.com/public.nsf/allkb/C4B6EF55C6948A27862572B30068BF91
If you have Simulation Module in your VIs, you also want to upgrade to Simulation 8.2.1. Here is the site if you have Simulation 8.2:
http://digital.ni.com/public.nsf/allkb/BAB5EB4D5E64D71E86257261002BCFD1
Hope this helps!
Barp - Control, Simulation, RTT and HIL - National Instruments
(2,927 Views)
I should have spent a little time searching the Knowledge Base.  The referenced fix was very easy to perform and it resolved the problem.
Dave J.
(2,916 Views)
