Can't change front panel background
Pine background selected, but that looks like the oak.
Sounds like something is messed up in the background folder.
Could you show us a screen shot of the folder?
C:\Program Files\National Instruments\LabVIEW 2020\resource\background
You can also use your own image instead of the built-in images.
George Zou
Message 11 of 12
(243 Views)
OK,
  1. The MT.vi is a blank vi with no artifact
  2. The "snippet" is just an image of a snippet with no actual snippet
So, Is that really an "artifact" (constant steady in one location) or "Ants Marching" like an active selection.
I strongly suspect that you have done "Something Bad (TM)" to the original vi Pane
Run the attached vi
Snippet in 2022Snippet in 2022
Which is back-saved (to 2020) from this snippet in 2022
"Should be" isn't "Is" -Jay
Message 12 of 12
(223 Views)
