Can't change.NET container BackColor property in en EXE
Good afternoon to all,
I have been trying to change a .NET Container background color programmatically and in works perfectly fine in LabVIEW.
I then try to compile my application into an executable and nothing happens... In the best case, I get an error 1 and the background remains black. In the worst case, the application just crashes.
Would someone have an idea of what the problem might be? Or maybe an exemple on how it works with an EXE?
Is there any dependancies to set when building the EXE when it comes to .NET assemblies?
I can post an example if needed 🙂
Thank you in advance for your help.
CLAMaxime -- Kudos are a great way to say thank you
(2,143 Views)
For information, it seems that I am not able to replicate the problem on a new project.
(2,116 Views)
