Can't boot RT from PC hard drive
I have a PC with a removable hard drive successfully booting the RT software.  I have an identical hard drive that I am attempting to format in the same manner.  I have gone through the procedure for formating the PC hard drive as per instructions and I keep getting the following error message:
Reboot and select proper boot device
or insert boot media in selected boot device and press a key
I know the new hard drive works because I can successfully boot to RT from a floppy disk.  For whatever reason the hard drive does not appear to be formatting correctly even though I don't get any errors after the format process is done.
Any help you can give me is much appreciated
Kevin
(3,082 Views)
Oops, I accidently posted this in the Labview forum.  I cc it over to the labwindows/cvi forum
(3,081 Views)
