Can't access format & precision menu from front panel
Labview 7 seems to have stopped allowing me to access the format and precision, data range, and properties menus from the front panel. I create a blank VI, drop a numeric control onto the front panel, right click and select format and precision... nothing happens. I can hear the computer thinking about it but no menu pops up. Same for the data range and properties menus. Other front panel objects with different pop-up menus are also not working.
Anyone else run into this problem before? I keep thinking I must be missing something obvious but I can't figure out what it might be.
JW
(2,449 Views)
Problem is fixed. May have been the result of very low available disk space on my system partition. I was down to a few megs. Took off a couple of unused programs and it seems to have corrected the problem.
JW
(2,445 Views)
