Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
01-07-2015 08:08 PM
I want to test NI 5782 adapter module with the FlexRIO FPGA module NI PXI-7954R as the target. Unfortunately the example project I have is corrupted and I am unable to reinstall it. Can someone please post the example project NI 5782 - Getting Started on this forum. In LabVIEW in the NI Example Finder you will have to select Hardware Input and Output>>FlexRIO>>IO Modules>>NI 5782. I will be grateful. I am using LabVIEW 2013.
Kathar
Solved! Go to Solution.
01-09-2015 10:21 AM
Here you go
01-11-2015 11:49 PM
Thank You Super-Britton. You are a life saver.
Kathar
