Can someone backsave this from 8.0 to 7.0?
There are a lot of missing VIs (OpenG mostly) but you can just tell LabVIEW to ignore them. LabVIEW should be able to backsave even if it can't load them.
___________________
Try to take over the world!
(2,927 Views)
Dear tst,
I can't able to download the llb from ur attachment. I tried 50 times but not able to download and save in my PC. Even i can't able to open directly without saving.
Could you please reattach it once more.
Mathan
(2,917 Views)
I'm not sure what the problem is. I am able to download it with no problems.
As I mentioned, there are some VIs missing, so you should get some warnings when you open it, but that should not prevent backsaving.
___________________
(2,906 Views)
Hi tst,
It gave beaucoup errors, but here it is.
Jim
LV 2020
(2,903 Views)
Thank you both. It opens fine in 7.0.
Now I just need to fix the code and test it.
___________________
(2,895 Views)
