Can only display chart with date and current time, not test time
Hi everyone,
I have a very simply program in which I'd like to display the chart with the test time. That means that it the x-axis should start at zero (if I clear the chart data) and then increase from zero. However it keeps displaying the date and time instead. I tried everything in the properties and I can't modifiy this. Is there something that I am missing?
Thank in advance!
(2,326 Views)
The "Waveform" data type includes 3 things:
  • The start time of the waveform
  • The distance between each waveform point
  • An array of points
Since you're using a waveform data type, the graph uses the 3 parts of the waveform to find the time.  If you look on the "Waveform" palette, in the "Analog waveform" sub-palette, you'll see a VI called "To XY Pairs", and if you use that you can wire it to an XY graph instead.  If the X axis isn't what you like, you can do some math on the X coordinates to make them start at zero and match your intended graph.
(2,312 Views)
Did you try going to the properties for the chart and set the properties for the X-scale axis to be Relative Time instead of Absolute Time?
(2,284 Views)
