Can not use driver converted from Labwindows
I have an old instrument, HP6060A, in the idt there is only labwindows driver.
I created labwindows dll from the evaluation software and opened my labview and created a wrapper from the dll.
However I was trying to get the initialization vi work. The original c definition is:
int hp605xa_init(GPIB_Address, ID_Query, Reset_Device,
                                Instrument_ID);
where the GPIB_Address is an interger from 0 to 30. I tried to get this vi work but always get an error of 230 which is Error writing to instrument
The GPIB address is matched and I double checked the GPIB cable, it is fine. Am I missing something here? Do I need more library files to get this working?
(2,711 Views)
There are LabVIEW drivers here for the 6060B. Perhaps those will work for you. Usually the letter at the end indicates a different current/voltage/power range.
(2,702 Views)
