Can labview be used in high vacuum systems?
I want to use Labview to control carbon dating sample processing which occurs in a high vacuum system. My question is, it is possible to use labview?
(2,794 Views)
I don't see how having a high vacuum has anything to do with Labview, unless you're putting your whole PC in it!
What sort of sensors will you be using? I assume you will be using a standard DAQ card to convert the sensor data. A few more specifics would be helpful.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,794 Views)
Regina,
Yes you can. Could you be more specific on what intruments you are using?
(2,794 Views)
