Can i use a GCC compiler on MacOSX and link this C Code to lbv 6.1 on OS9?
I am interested in compiling my C code on the free GCC compiler which works with Mac OS X but am concerned that I will not be able to connect this with the Call library function and CINs in labview 6.1 that runs on Mac OS 9. Am I able to cross platforms and use the .so file with lbv 6.1 on OS 9? What problems will i most likely encounter or should watch out for? Thanks!
(2,566 Views)
Unfortunately, you cannot port shared objects across these platforms. You are going to have to recompile the .so file on OS 9 for use in the call library function node.
Robert Mortensen
Software Engineer
(2,555 Views)
