Can i use Handle C with the LABVIEW FPGA module?
Can i use Handle C with the LABVIEW FPGA module?  I am working with CompactRIO right now so, i want to know weather i can use Handle C with CompactRIO.Can i access FPGA in compactRIO independant of LABVIEW  means can i program it without using LABVIEW?
regards,
Vishnu.
(4,606 Views)
In order to program your FPGA, you will need LabVIEW.  Also, you cannot access C based DLLs in LabVIEW FPGA.
(4,489 Views)
Hi Vishnu,
Although we don't support Handel-C directly, it is possible to design your algorithms using 3rd party tools or system integrators and consume them from a top-level LabVIEW VI. The webcast at http://zone.ni.com/wv/app/doc/p/id/wv-268 shows an example of how you can use IP from C-based tools provided by Celoxica in the LabVIEW FPGA environment.
(4,487 Views)
