Can i replace a Plot data with an image in an XY Graph?
I want to build a VI where the plot data or the points in an XY Graph is replaced by an Image. Is this possible?
(2,987 Views)
Hi Pranesh,
Yes.
Graphs support to embed upto 3 images, for front, middle and background…
For reference you might look for the "Plot images property" example VI in the example finder!
(2,982 Views)
Thanks a lot. Now I'm able to insert an image into the plot. But how do I control the position of the image? Lets say I want an image at an X and Y axis point, How do I do that?
(2,964 Views)
Hi Pranesh,
the image is embedded at the upper left corner of the graph plot area (from my mind, please test again).
To move the image to a different position you need to create a larger image and place your "sub"-image at the right pixel coordinates…
(2,953 Views)
Hi Pranesh. Did you find a way to put an image in a specific point in the graph?
(2,803 Views)
