Can horizontal scroll bar be removed?
The listbox controls have horizontal scroll bar that can not be removed by property notes. Is there a way to change it to invisible? Also how do I change the controls from raised or recessed to flat? Thank you for your help.
(2,662 Views)
The only listbox with a horizontal scroll bar is the multicolumn listbox and it does have a property node to remove it or display it. In 8.5, the property is Visible Items>Horizontal Scrollbar Visible.
There are modern controls, classic controls, and system controls on the palette. Pick the one you want or right click on an existing one and select 'Replace'. You can also right click and select Advanced>Customize.
(2,655 Views)
