Can data be accessed via labview from the computer serial port?
I want to access the serial port with a labivew vi only and no external hardware.
(2,474 Views)
I am going to assume that you wish to communicate to some device connected to the serial port. You read and write to the serial port using VISA Read and VISA Write. These functions as well as a function to configure the serial port (baud rate, etc.) are on the Instrument I/O>Serial palette. You can also use the Instrument I/O Assistant. There are shipping examples on serial communication and if you go here, you'll find links to tutorials and other examples. The only external hardware you need is a cable to your device and the device itself.
(2,474 Views)
