Can anyone help me converting a spectrogram to an image (picture)?
(4,022 Views)
Is the spectrogram currently an internsity graph?
To get a picture of the indicator, do a "right-click...create...invoke node...get image" and wire the desired image depth and background color.
Now you can e.g. save the image data as a PNG or display it in a picture indicator.
(4,017 Views)
The output from the invoke node is in the form of cluster but the input of picture indicator is different. so im not able to connect.. can u please help
(3,685 Views)
Hi Reeni,
you should create your own thread instead of highjacking very old ones.
And while you do this please explain your problem in more details. Attach a VI or atleast a snippet of the block diagram!
(3,679 Views)
Use draw flattened pixmap to draw image data in a 2D picture indicator.
(3,652 Views)
As has been suggested in Reeni's own thread
(3,647 Views)
