Can a user retrieve code that was loaded to a CIN?
I am looking at an application that uses a CIN to call some external code in order to collect data from a test stand.  If possible, I would like to extract and view the original code that was loaded into the CIN so I can determine data collection methodology.  Is it possible to see the original code that was loaded into the CIN (assuming the original file is not on the computer)?
(taken from the LabView documentation)
"If you save the VI after loading the code, LabView no longer needs the original code to execute the CIN.  you can update your CIN object code with new versions at any time."
(2,612 Views)
If you don't have the original code, then there's nothing that you can look at. It's no different than trying to read a windows exe or dll file.
(2,605 Views)
CIN uses a customized dll.  No source code in it.
George Zou
George Zou
(2,597 Views)
