Can NI-DAQ 6.5 use Windows XP USB with a patch or update?
I am now trying to interface LabVIEW with hardware via NI-DAQ, but my NI-DAQ version doesn't seem to work with Windows XP. Is there a patch or update I can download or acquire free of charge that would allow NI-DAQ 6.5 to interface via Windows XP USB ports? The USB recognizes that there is a device plugged in but there is no communication going on.
(3,120 Views)
The latest version of NI-DAQ can be found here. The first reference I can see to WinXP is for version 6.9.2 according to the list here.
(3,120 Views)
Respected Sir,
In my old labview 5.1 version, Ni-DAQ 6.5 was used.
I would kindly request you to please tel me which NI-DAQ version is used for labview 8.2 and also compatability to support hardware already used in 5.1 version.
Thnaking You
Yours faithfully
M. Vijay
(2,750 Views)
Did you try a search? http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
NI-DAQ was renamed to Traditional DAQ since it was replaced by DAQmx. New designs should use DAQmx unless you are using a card that is not supported by DAQmx. The Release Notes for the specific DAQmx version will tell you what devices it supports.
(2,745 Views)
Respected Sir,
Thank you very much for your kind help.
I install NI-DAQ 6.9.3 in labview 8.2 and is also compatability with labview 5.1.
I open the old computer window 95 cpu to find any national instrument PCI card is present or not, but i not find any PCI card.
Actually the instrument  run by (labview 5.1, windows 95, Fieldpoint 1000, FieldPoint Explorer 1.6, NI-DAQ 6.5.1) is worked by other persion is retired from the department.
It was worked perfectly and take measurement by them.
The probelm now i received is connection to auquisition board was not found when i run probe.vi file in labview.
If FieldPoint 1000 hardware is using he instrument means there is no need TO USE NI-DAQ PCI card?
I would kindly request you to help, i do not know what to do now.
Thanking You
Yours faithfully
M.Vijay
(2,734 Views)
