Can NI 9253 sample faster than scan engine?
I have a cRio 9047 in hybrid mode with a 9253 sampling at 2 kHz on FPGA and three 9512s deployed under scan engine (scan rate is 1 kHz). I know the 9253 is DAQmx compatible. I also know the 9047 is DAQmx compatible as I have a 9217 sampling two RTDs with DAQmx. What I don't know is if I can deploy the cRio as scan interface, move the 9253 to DAQmx, and sample that at 2 kHz. I've never been clear on whether or not a DAQmx device can sample at a higher frequency than the scan rate at which the cRio is deployed. Thanks in advance.
(2,293 Views)
Ignore topic. NI 9253 is not compatible as DAQmx unless using LV RT 2019. I'm using LV RT 2018 thanks to Softmotion...
(2,249 Views)
