Can Max global channels be programmatically added to a created task?
I can add Physical channels to a created task, but cannot seem to add global channels to a task that was previously created.  The problem here is that I want to create my task with the channels (both physical and global) in a specified order.
Mike Sachs
(2,834 Views)
Hi Mike-
You can add global virtual channels to a programmatically-created task by using the DAQmx Create Task VI.  This allows you to create a task with existing global virtual channels and then add virtual channels at run-time in the usual manner.  Here's an example that shows a global channel (created for Dev5/ai0) and a virtual channel within the same task:
Hopefully this helps-
Message Edited by Tom W [DE] on 02-09-2006 11:06 AM
Tom W
(2,832 Views)
Alan's suggestion here gives you more control of the scan order for the task.
Tom W
(2,822 Views)
