Can Labview perform maximum entropy deconvolution for electrospray mass spectrometry data similar to MaxEnt from Water Corporation?
I have searched the internet for a user-made VI that imitates what the big mass spectrometry companies include in their software packages? Is anyone aware if Labview has the tools to do this?
(3,363 Views)
I have never seen such toolkit, but I use and used mass spectrometers from different companies. In one case the manufacturer provided a LV driver, so I was able to get the MS raw scan data, that was all I needed. I imagine, if you need further data analysis solution, you can either program it yourself, or pay for a developer to do so...
LabVIEW for sure is capable to do anything like other programming languages, so for that question, yes, LV has the "tools".
edit: I have found some case study, it might or not give you ideas: http://sine.ni.com/cs/app/doc/p/id/cs-13003#
(3,322 Views)
