Can Labview control an Omega DIO? http://www.omega.com/DAS/pdf/OMG-USB-DIO48.pdf
Is there a driver for this?  http://www.omega.com/DAS/pdf/OMG-USB-DIO48.pdf
(3,574 Views)
Looks like there is nothing on the Instrument Driver Network for this data acquisition device.  Looks like you will have to code it up yourself.  And I am going to wish you good luck and I hope that your interactions with technical support at Omega are more fruitful than mine.  Given that you will have to code this up yourself, have you considered using one of the NI DAQ devices - there are a ton out there on a variety of platforms that should do what you want to do with this one I suspect.
Cheers, Matt
(3,566 Views)
Looking at the user manual, it appears that the device is really a Sealevel device that Omega has rebranded.  Sealevel looks to have the things cheaper than Omega and the software is downloadable from their website so you could see what their API is and the help file has descriptions on how to use it.
(3,551 Views)
Sidenote- In my experiences, a lot of Omegas offerings are rebranded. Thus techical support from Omega can be lacking at times. As Matt indicated, try to go to the original source for the best information.
-AK2DM
(3,539 Views)
