Can LabView 8.5 read LabView 8.5.1 VIs
Since LabVIEW 8.5.1 is only a bug fix, can LabVIEW 8.5 read any VIs generated in LabVIEW 8.5.1?
(2,537 Views)
Simple answer YES. But it will the VIs compile so it is a good idea to make a mass compile in the folder where the VIs are.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,532 Views)
