Can LabVIEW work with https (not http)?
I have trouble to use LabVIEW 6i to GET response from HTTPS server. It works with HTTP server smoothly. (I changed the port 80 to 443.) Are there any package can work with HTTPS? BTW, I also have LabVIEW 7 and will use that if 7 has the solution.
(6,227 Views)
HTTPS means that the data is encapsulated in some sort of secure
protocol layer such as SSL. You do not want to implement SSL in LabVIEW
I think.
In order to establish a meaningful connection with an HTTPS server you
need to establish a secure context with authentication through
certificates, crypto algorithmes and such. For this you have specific
libraries like OpenSSL and such and you could call them as an external
library. But you can not plug them into the LabVIEW TCP/IP functions to
let
them transparently handle your TCP/IP communication.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(6,227 Views)
Please take a look at the document below that discusses LabVIEW and HTTPS
Does the LabVIEW Web Server support SSL and https?
Sincerely,
Feroz
(6,227 Views)
If you want to use labview to GET response fron HTTPS server you can use the activeX with the windows HTTP Services (winhttp.dll).
See the link for more information about the windows HTTP Services
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/wininet/wininet/wininet_reference.asp
Cyrille PLANARD
(6,227 Views)
