Can LabVIEW Run-Time Engine 7.0 control LabVIEW 6.1 VIs?
I'm attempting to remotely control a LabVIEW 6.1 example VI through the browser plugin on another system. On that other system, can I use LabVIEW Run-Time Engine 7.0? Or do I need 6.1?
(2,995 Views)
Never mind, I should have read the RTE 7.0 information first. I need LabVIEW Run-Time Engine 6.1 to run LabVIEW 6.1 VIs.
(2,995 Views)
I have found that LVRTE 7 does support EXEs built using LV 6x.
(2,995 Views)
