Can I write a C program about a matrix in Formula Node function(in Structure)?
Dear All,
I want to write a C program about a matrix in Formula Node function (in Structure). However, I do not know how to define the matrix, anyone can help me? Here is the details about the C program:
for i=0:7;
   y(0,i)=data(0,i);
end
data is an input terminal and y is an output terminal.
I know I can achieve this purpose by other function in LabView. But I think it will be more convenient if I can write a program like this. Thanks in advance!
Quanzeng
(3,236 Views)
you should do it like this:
int y_matrix[10][10];              //matrix with size 10x10
int data_matrix[10][10];
int i=0;
for ( i=0; i<8; i++)
    y_matrix[0][i] = data_matrix[0][i];
But it is not clear for me what you want to do, because you are only writing data from one matrix to an other one.
Christian
Message Edited by Christian_M on 08-08-2006 03:46 AM
(3,229 Views)
Thank you for your reply. But I can not make the program work in the LavView. Are there some tricks?
(3,214 Views)
Hi
Please try the MathScript Node, it is easy to create a matrix and perform matrix operation in MathScript Node.
(3,200 Views)
