Can I use multiple custom error code files within a single labview application?
I have a modular scalable labview app that can add systems to it as I add additional systems to test.  My question is how do I handle it when each of these  systems have their own custom error code files?
(2,740 Views)
Just select the "Copy Error code files" check-box on the Advanced tab of the build spec.
"Should be" isn't "Is" -Jay
(2,725 Views)
I see this dialog check box but what I am asking about is if there is a way to use more than one error code file "error codes.txt" for building a project.  If one developer is writing a VI which is a child VI of the main program and he wants to use his own custom error codes in his child VI, how can I integrated that during build with parent VI if the Parent VI has its own error code.txt file also?
(2,717 Views)
Hello id,
Yes, this should be possible - as per the LabVIEW help, all you should need to do is include the custom error files in the errors directory for the version of LabVIEW/Labview Runtime you're using.  When deploying your plugin children, you'll just need to ensure that the new error files are installed to <root>\National Instruments\Shared\LabVIEW Run-Time\<version>\errors\. If you're building an installer, Jeff's suggestion should take care of that.
Note that a valid error file is named <something>-errors.txt.  You can have any number of these files.
Once you've placed that in the correct directory, any time that error is passed to a standard error reporting VI I believe the comment should be pulled from those files. If error numbers are duplicated, it should display all applicable comments.
For reference:
Defining Custom Error Codes to Distribute throughout Your Application
https://www.ni.com/docs/en-US/bundle/labview/page/defining-custom-error-codes-to-distribute-througho...
Tom L.
(2,713 Views)
