Can I use executables built using Appbuilder (windows version) on Linux with installed runtime engine?
Hi, I need to develop test routines for an ATE tester running Linux OS that does not have LabVIEW installed. I will be building my project using a windows version of LabVIEW and build executables using the appbuilder. Can I use these executables that I built in windows  assuming I installed the correct runtime engine in the linux platform? FYI, I need to develop the test routines on an IMS Vanguard 500 ATE.
Thanks.
(2,789 Views)
I have never tested this and am not 100% sure of my answer... Smiley Indifferent
I would answer NO, from what I remember you can share the code (VIs and LLBs) form a platform to another but not executables ; LabVIEW for windows will build EXEs for Windows, Linux for Linux, MacOS for MacOS and so on...
I will check this with my colleagues and get back to you to confirm.
Epictetus
Antoine Chalons
(2,784 Views)
I confirm what I told you earlier.
The code is multiplatform, but not EXEs ; they will only run on the same platform (OS) you built them with.
Epictetus
Antoine Chalons
(2,773 Views)
