Can I use SubPanels to display and run multiple executables from the same GUI?
Thanks for all the posts.  I was finally able to get the functionality I desired...running three instances of a Main VI from one top-level executable.
I  made my Main.vi into a VI template and then open multiple references to this template from a top-level VI.  While there are ways to get re-entrant behavior out of FGs (link) I decided to eliminate any FGs I had and to pass the data using wires or queues instead.  All my SubVis were made re-entrant.
I then insert each of the Main.vis into separate Subpanels on my top-level VI (each running a separate instance of the Main.vi).  Each instance of teh Main.vi communicates with an indivdual USB-6008.
Works well.
Dan
Message 11 of 41
(1,705 Views)
I would like to take your idea just one step further - I was hoping you (anyone actually) could tell me if this is feasible.  In your case, you had two instances that you ultimately rolled up into one top-level VI.  In my case, I will have anywhere from one to 16 instances that I want to have the top-level VI control.  I envision a client telling me how many apps he needs, I programmatically create that many, then the client sends me a TCP message (with some ID to direct the message to the correct app).  Does this dynamic growth seem possible?
Message 12 of 41
(1,632 Views)
Another clarification question - If I understood you correctly, you enveloped your LABVIEW code into a DLL, correct?
Message 13 of 41
(1,631 Views)
You mentioned that "All my SubVis were made re-entrant".  What is done with VIs from third-party vendors?  I am not able to select the Execution properties of those VIs.
Message 14 of 41
(1,625 Views)
In response to:
No, I made the top level VI a VI template and opened separate instances to this template
In response to:
If the third party VIs need to maintain separate data space then they need to be re-entrant, even when opening seperate instances of the template vi.
In response to:
Anything is possible...
I ended up having three separate instances, 3 or 16 shouldn't matter.  Just create the instances in a loop as needed.
Dan
Message 15 of 41
(1,620 Views)
1) How do I make third party VIs re-entrant?
2) Can you elaborate on how you ".. made the top level VI a VI template and opened separate instances to this template"?  Not sure how to do those two things.  I think I read that the VI Server is involved when trying to call this template, but I'm not sure what that looks like.
Message 16 of 41
(1,618 Views)
1) A VI is a VI and you make any VI reentrant by going to VI Properties>Execution. If a VI that you created or someone else created is password protected, then you cannot make changes to either the code or properties.
2) You make a VI a template by doing a save as .vit. Calling a template is really no different than calling any other VI. You can call it statically or dynamically. Calling a VI dynamically with VI Server is shown in several shipping examples.
Message 17 of 41
(1,614 Views)
1) (a) Either get access to the source code from the thrid party, or (b) looks like the reentrancy is a VI property (Execution.IsReentrant), use a property node to set this property for all exes.  To do this you will need to open a reference to the VI that is part of the third party build.
2) All you need to do to make a vi template is Save As..with a .vit extension.  Then just use open VI reference to obtain the reference to the template.  Each reference will be a separate instance.
Also see:
http://decibel.ni.com/content/docs/DOC-7721
http://digital.ni.com/public.nsf/allkb/98847B4E4C715E6D86256C59006B57CC
http://zone.ni.com/reference/en-XX/help/371361F-01/lvhowto/creating_vi_templates/
Dan
Message 18 of 41
(1,612 Views)
I am curious why the Main.vi needs to be a .vit (template) file if it is to be used as a dynamically loaded reentrant vi.  According to the documentation, you can convert a vi to a vit just by adding the "t" to the end of the filename, there is no difference in the code at all!
Message 19 of 41
(1,605 Views)
With regards to the VI & VIT, is there a need to maintain both.  Just looking at configuration management issues.  It seems like you need the vit to do the template, but can a vit be used outside of a template (i.e., can I make an EXE out of it)?
Message 20 of 41
(1,579 Views)
