Can I target the STM32VLDISCOVERY dev board with labview embedded for arm?
Hi all,
I would like to know if I can target a STM32VLDISCOVERY dev board (http://www.st.com/internet/evalboard/product/250863.jsp) with the labview embedded for arm microcontrollers module. Thank you.
Charles
(2,326 Views)
Hi Charles,
That dev board is supported with the LabVIEW Embedded for Arm. However it is only supported at a tier 2 level. This means that you may have to do some development on drivers for that particular board.
If you do decide that you want to use this board I would suggest reading through this article.
<Brian A | Applications Engineering | National Instruments>
(2,300 Views)
