annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Can I run applications (.exe) built in LaVIEW for Windows in a Linux plataform?
We've got LabVIEW version 6.1 for Windows and we've built some applications (.exe files) with it. Now we want to run these applications in a Linux system. The question is: if I install Run-time engine version 6.1 for Linux, will my applications work? PS: I can't find the run-time engine version 6.1 for Linux in NI web site, only version 7, but it is supposed to work only with applications built with LabVIEW 7...
Messaggio 1 di 2
2.648Visualizzazioni
You need to rebuild your application for each OS. However, you can try the windows emulator for Linux, Transgaming's WineX.
-Joe
Messaggio 2 di 2
