Can I programmatically copy vi within llb AND build an application?
I previously posted the question how to programmatically work (copy, delete) on files within llbs and got two answers to use the librarian vis in vi.lib > utility > libraryn.llb
That works really good but only till I try to build an application. The application builder seems to use the librarian vis also and complains that it cannot build an application with vis that are currently in use...
Any idea how to solve that?
Cheers, Daniel Troendle
(3,333 Views)
Make a copy of all the VIs used by the librarian and save them under a
different name (making sure to link the sub-VIs to the new name of course.
Awkward, but it should work.
Shane
D. Troendle schrieb in Nachricht
<5065000000080000001A200000-991728092000@quiq.com>...
>currently in use...
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(3,333 Views)
Yeah, it's really awkward 😞 but it really works :-))
(3,333 Views)
> currently in use...
Close all VIs before you launch the application builder.
Mark
(3,333 Views)
I guess it's kind of tricky to close the application builder before building an application?
(3,333 Views)
