Can I manually set x-y grid size on the waveform graph?
I want to fix grid size at 1*1 cm no matter how wavefrom changes.
Is it possible to do it? Thx!
(2,892 Views)
First thing you can do is disable the "AutoUpdate" for the Y and X scale by right-clicking on it... see below.
To make it 1cm*1cm... hmmmmm... if you set it as you want and lock it, they shouldn't move.
Message Edité par TiTou le 06-26-2006 03:50 PM
Epictetus
Antoine Chalons
(2,880 Views)
The size should not be changing, however the scales may be changing if you're auto-scaling.  You also have programmatic access to the size of the plot area using a property node - run the attached VI which illustrates this (I attached in version 7.1).  If you're still having problems, please explain in detail the behavior you are trying to implement or avoid - perhaps you can attach a very simple example which shows it!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,871 Views)
