Can I load a list of hex numbers into an unsigned 8 array?
Here is a couple of ways to do the whole thing, with the numbers before and after:
19569iF6BAFF4E47A6FE88
- tbob
Inventor of the WORM Global
Message 11 of 17
(1,228 Views)
The CAN controller wants a hex message, so in the U8, I plug in 3 22 28 1C, each in a separate field.  Here is the test file, a simple text with those messages (minus 3 22)
Message 12 of 17
(1,225 Views)
tbob, thanks, but what I want is the values that are in the input to be in the output array.  03 22 string converts to 03 34, but I want 03 22 (or similar) in my U8 array
Message 13 of 17
(1,215 Views)
Accepted by topic author cnassouri
Try this
Message 14 of 17
(1,203 Views)
That is absolutely perfect...thank you so much!
Crystal-
Message 15 of 17
(1,192 Views)
If you right click on the output array and select Display Format, then select Hexidecimal display, you will see 03 22 etc.  The number is the same internal to the computer.  The display just shows up differently, it won't change the data you are sending at all.  Actually, the computer stores 00000011 00100010 and sends that.  Change the display to binary to see that display type.
- tbob
Message 16 of 17
(1,188 Views)
Thank you,  I was breaking my head over this for a couple of days.  Now I have two ways, appreciate all the help.
Crystal-
Message 17 of 17
(1,185 Views)
