Can I grab data from the last cell in a column in Excel from Labview?
I need to grab data that another program, not under my control, is logging to an Excel spreadsheet. I tried using the Excel/GOOP toolkit but the problem is I need to always grab the *last* few points in a column. I can't see a way to do this using the Toolkit. Anyone have any ideas?
(2,555 Views)
Using activeX calls, you can check used range in the sheet, and then retrieve any data that is on it, including the last used cell.
Hope this helps
(2,555 Views)
