Can I give command print to HP color printer from LabVIEW 7.1..?
Hello.. 🙂
Can I give command print to HP color printer from LabVIEW 7.1..? I have application in which I have to calculate  some numbers & print them with fixed text... Is it possible to give print command from LabVIEW 7.1 to HP color printer...? Can anyone please help me...?
 Thank you for any help from you.. 🙂
(3,022 Views)
Accepted by topic author Rupali
You will probably find a solution using the Report generation VIs. You can create a report, insert any data and text you wish, and print it either on the default printer or on a named printer. The report generation VIs are at the bottom of the Programming palette.
Chilly Charly    (aka CC)
(3,007 Views)
Thank you for reply.... 🙂
(3,004 Views)
