Can I get a different color than black in Threshold?
I am using IMAQ threshold functions in my application. The user, however wants to be able to select between two different colors instead of one color and black. How can I do this?
PaulG.
Retired
(3,489 Views)
Hello.
Sounds like you are essentially dealing with the display of binary images. What you see when you display a binary image is simply what is defined in the Color Palette for your image display. There are many different environments/displays (CWIMAQViewers in VB, LabVIEW Image Displays, etc), but the concepts remain consistent. Basically, when you map an image to binary, you change the pixel values to 0 and 1 (typically). The way the image displays work is that they map an 8 bit integer value to a specific RGB color. What you see in the LabVIEW image display when you select 'Binary' as the palette type is black for a pixel value of 0 (0R, 0G, 0B), and red for a pixel value of 1 (255R, 0G, 0B). This behavior can be changed, however,
by adjusting the color palette.
I have attached an example VI that demonstrates this concept (LabVIEW 7.0 format). You can map any color you wish to pixel values 0 and 1, and therefore should be able to get what you are looking for.
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,489 Views)
It worked! Thanks!
PaulG.
Retired
(3,489 Views)
