Can I extract a VI from an .exe build?
On both Windows and Mac machines files are at least potentially backed up automatically to some degree. If you're on Windows, you can right click a file or folder in Explorer and select "Restore previous versions". These are not guaranteed to exist, but they might.
There was some work done a while back on LAVA to recreate VIs from the machine code in an EXE, but I don't remember the details or where it ended up. It certainly wasn't a full decompiler and it would not get you the original code back.
___________________
Try to take over the world!
Message 11 of 12
(369 Views)
@santo_13 wrote:
@LVIEWPQ wrote:
@GerdW wrote:
Hi LVIEWPQ,
@LVIEWPQ wrote:
It's not my VI or .exe
So you want to "hack" someone else's code?
That's considered "illegal" (under certain conditions) in some countries…
Ask the author of that software about the changes made to the software!
More of the inherited code problems.
Created a VI > Built exe > modified VI for use elsewhere
The original VI used to build the exe has been modified and now doesn't produce the same results on the original machine.
Wakeup call to standardize your process, documentation and source control. This is an excellent example of what a new engineer has to go through if someone left the org without documenting and storing the source somewhere.
Exactly, This is what I am in the process of doing, hence trying to get access to the old VI so that it can be documented properly.
Message 12 of 12
(360 Views)
