Can I do triggering and manual control simultaneously on one card?
I have a PCIe 6323 and can I generate triggering output on, say ao0, while setting up a GUI for, say ao1, for users to manually set a constant output on ao1?
(2,780 Views)
Accepted by topic author joehsiao
joehsiao,
Yes, you should be able to, provided you do not need the accuracy of hardware timing. The DAQmx driver limits you to 1 hardware-timed analog output task at a time, so you could only run both these outputs at the same time if one, or both, task is software timed.
You can find more information in the following article: How Many DAQmx Tasks Can I Run Simultaneously?
Let me know if this helps.
Patrick O.
Applications Engineering
(2,735 Views)
