Can I display Hex wave in Labview?
Can I display Hex wave in Labview(not only Binary wave)? Is there any
way to do that? If I can show you the hex wave graph , you will know
what I mean more clearly. But I can't put it here. Hope you all know.
(2,884 Views)
Hex is just a way of showing values.
In the real world people are interested in
decimal coding: 0 1 2 3 4 5 6 7 8 9
, but doing technical aplications,
the Hex coding: 0 1 2 3 4 5 6 7 8 9 A B C D E F is more popular.
If you want to show values in hex in a graph simply right-click y-scale - formatting Format: Hexadecimal.
Patrick
(2,884 Views)
If I can post an image , things would be better to understand.
I don't mean to display digitals in Hex ways but to display it in a
special way but usually used in the timing analysis of digital signal.
some like the following graph.
__________________ ________ _____________ ________________________
_______
___9F_____________/\___8A___/\_____12______/\________5C______________/\___6D__
(2,884 Views)
> _______
You don't say what version you are using, but I believe that starting
with LV6.0 there is a graph in the palette called the digital graph. It
can show group lines/busses and the value of the bus can be shown in
various numeric formats including hex.
Greg McKaskl
e
(2,884 Views)
