Can I convert a Lookout application into a labview application?
We here are seriously thinkig to migrate to Labview. There is a complex application done with Lookout 6.0 that we want to convert to a labview application. Having the proper Labview, is there a way of compiling it, open and save, or convert the Lookout application into a Laview application?
Excuse my ignorance in this matter.
Best regrads.
Rudy
(3,397 Views)
Accepted by topic author 23r23
Hi rudy,
The forums search very oftn gives an answer: http://forums.ni.com/ni/board/message?board.id=190&message.id=5193&requireLogin=False
(3,390 Views)
Labview 8.0 has drivers for a Delta Tau Turbo PMAC II PIC Card?
If yes:
Is the version of Labview for Linux capable of communicating with this type of Motion card inside the same computer via PCI BUS?
For the end:
What flavor of Linux is the appropiated for Labview 8.0?
Regards.
Rudy Lopez
(3,362 Views)
Sorry, the driver asked if for a Delta Tau Turbo PMAC II motrion control PCI card. We currenty use 4 axis of motion.
Best regards.
Rudy
(3,360 Views)
Rudy,
First of all I hope you first question regarding lookout is solved. If so then mark my answer as solution.
For the next time, if you have other questions, which are not related to the one you started the thread of, then open a new thread!
And no, National Instruments don't has drivers for Non-NI Products, so LabVIEW has no driver for your motion card. Anyhow National Instruments has it's own Motion Hardware and Software (ni.com/motion).
And for LabVIEW and Linux just go to ni.com/linux, and you will find supported hardware/software and the linux derivates it works on.
Christian
Message Edited by Christian_M on 11-20-2009 01:28 AM
(3,347 Views)
