Can I configure LabVIEW so that connector inputs are requried by default?
Is it possible to configure LabVIEW 7 such that when I create a VI and setup its connector all inputs are requried (rather than recommended) as default?
Generally, when I make a sub-VI, I want all of its inputs to be provided by the calling VI.  It is the exception that they should be recommended / optional instead of required.
(3,068 Views)
I have never heard about a setting in LabVIEW that makes all input terminals on the connector pane "required" connections.
Your subject may be handled by creating VI templates with appropriate "required terminals" and use them as a starting point when creating new VIs.
(3,057 Views)
Hi
There is no option to change the default for recommended or required. By default they will always be recommended.
Regards
Tim
AE | NI UK and Ireland | Technical Support
(3,016 Views)
Wouldn't it be good to have such an option?
(3,010 Views)
