Hi Dennis
I'm running on Windows, too. And so the EOL should default to CR/LF. But - when I use a string constant and let it have more then one line, the EOL becomes a \0A instead of a \0D\0A (in HEX). For now I've taken the MatchPattern VI to select LFs without CRs but as I have to keep the time consumption very low it would be nice to have the EOLs in the string constant set to CR/LF.
Cheers, Daniel
