已解决! 转到解答。
Go to Tools > Options > Colors, and there you can change (among other things) the foreground and background colors of blinking controls.
Good luck,
-D
Aha,
thanks a lot Matthew, for this tip. I was wondering about the same, since the color options are application dependent (settings apply only to the particular machine), so when I create an installer to install my programs somewhere, I should include these settings. And you just said how.
Will get back here if I have doubts about this, when I build the application.
Kudos again!
Hi
Three years after you posted this tip, I made use of it.
That was my exact requirement, to set the Blinking colors in the Executable. I was unable to achieve this as the EXE uses Red and Yellow default colors when blinking.
I thought there was a property node that used to set the blinking colors. I am not sure if I was imagining, though.
Thanks again! It saved my time
