Can I Run a labview application in a hidden window (i.e. I don't want the front panel to pop up in this Labview created EXE)?
We don't see the FP, but we see the icon of the exe
Message 11 of 15
(1,161 Views)
Hi nadia,
then why do you ask "How to hide the FP?"
To hide the taskbar icon you can edit the INI file of your EXE. Include the key/value "HideRootwindow=True"…
Message 12 of 15
(1,158 Views)
Thank you so much for your answer
I don't see where and how  can I include the key HideRootwindow= true
Message 13 of 15
(1,144 Views)
Hi nadia,
I repeat: "edit the INI file of your EXE"
Message 14 of 15
(1,138 Views)
If you are accessing your exe that often, you shouldn't be relaunching again and again. Rather you should leave it running in the background and pass data to it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 15 of 15
(1,118 Views)
