Can Communication lag
Hello Gerdw,
Please find attached the the part of code which is reading data.I can not share the log files which I have taken as logs contains data that is confidential.
Thanks in advance 🙂
Message 11 of 14
(909 Views)
Hi prajakta,
  • doing file operations, especially writing XLSX files, will slow down your main loop: use a consumer-producer scheme to decouple the process "CAN read" from "write data to file"…
  • at 250kBaud you should receive less than ~2000 messages per second: the producer-consumer should handle that very well…
  • when checking the ID you don't need to convert to a string. Just use an AND function to mask some bits and compare with an I32 value!
  • don't use ExpressVIs for writng files, use plain file functions to improve execution speed…
  • using a device driver with an enum item "standart" looks very suspicious to me…
Message 12 of 14
(903 Views)
Thanks for Quick Reply 🙂
I will try to implement the consumer producer scheme for CAN read.
I used the express VI for creating binary files (.tdms) whose writing speed is much higher than normal .xlsx file.Though I will implement basic File I/O operations to improve speed.
Enum 'standart' will select message type for CAN communication standard/extended.
Thank you so much again 🙂
Message 13 of 14
(893 Views)
Hello Prajatka,
Do you also have the other VI files of you CAN_Read.vi namely PCAN_INIT.vi and PCAN_READ.vi, PCAN_CLOSE.vi ? If so, can you please upload them here so I can start testing your main CAN_Read.vi ? Thanks! Mihai.
Message 14 of 14
(772 Views)
